What tires to buy?
Old Mar 9, 2009 | 01:02 AM
wrobo23's Avatar
You have a 2wd, correct? If so, you shouldn't have torsion bars.
Old Mar 10, 2009 | 12:21 PM
natemac27's Avatar
I figured that would be the answer. Hoped it wasn't.
Also when I put the body lift on will the exhaust pipe hang down like really low or what?
Old Mar 10, 2009 | 12:23 PM
natemac27's Avatar
And also, if I just put on a leveling kit how big tires can I fit? Or is that not for 2wd's either?.... 2wd's suck!
Old Mar 10, 2009 | 12:57 PM
ChrisT's Avatar
You can install a leveling kit on your 2wd, it will be fine. I will again state my original post. you can't go wrong with some 285/75/16 or 285/70/17 (depending on wheel diameter) BF Goodrich AT's.
Anything larger is going to be too stuffed, especially if you plan on hauling anything heavy from time to time.
Old Mar 10, 2009 | 10:01 PM
natemac27's Avatar
yeah i was afraid of that. how big tires can i get with a leveling kit? and if i get a body lift will the exhaust pipe hang down low?
Old Mar 10, 2009 | 11:45 PM
natemac27's Avatar
what about 3" leveling kit? what tires then? any pictures of a 2wd with body kit or leveling kit?
Old Mar 10, 2009 | 11:48 PM
natemac27's Avatar
haha! sorry i posted that so many times i didn't see it. my b.
Old Mar 11, 2009 | 10:04 AM
wandell's Avatar
You can't go taller than 2 or 2.5 inches with lift springs or coilspring spacers without getting new upper control arms. I'd combine these with a body lift and run 33's. Also, with a body lift your tailpipe will hang down 3 inches. It doesn't look bad and can easily be raised if you wish.
Old Mar 11, 2009 | 12:43 PM
squeaky3's Avatar
i would go with what wandell said
you could have an exhaust shop do your exhaust after a body lift so that there wont be a gap or you can just dump it so there is no pipes to worry about
Old Mar 12, 2009 | 11:32 PM
GaNole07's Avatar
I got the same truck as you, i currently got it ripped apart putting on a 3" bodylift, getting 1.5" leveling kit friday and some 325/60/18 nittos which equals about 33x13.00 on 18x9.5s sometime next week. I'll be sure to post up some pics
Old Mar 12, 2009 | 11:53 PM
squeaky3's Avatar
ya post some pics up when its done. i wanna see what a 33" looks like on a 2wd with just a body lift instead of a spindle lift
Old Mar 16, 2009 | 12:07 AM
RandallT02's Avatar
I have a 3.5 inch lift on my 02 and I have 315/75R16s They clear really good and they look great.
