electrical lighting problem
Old Mar 14, 2009 | 05:57 PM
vtox39's Avatar
I could use some help...........I have no illumination lights on panel, radio, climate control, steering wheel, or doors. I have panel dimmer turned up. All fuses check out fine....the wire for interior lighting is light blue with red stripe.....I used a test light and i have juice at that wire from the ignition switch but i have no juice where the wire runs into the back of the headlight switch. Where could the problem be and how does the wire run and split up after the battery and power distribution box?
thanks for your time
Old Mar 14, 2009 | 08:01 PM
jbrew's Avatar
If you ask this question in the right forum, I know you'll get plenty of help.
Old Mar 16, 2009 | 12:14 AM
SSCULLY's Avatar
Just a quick thought...might want to limit the posting of a thread to 1 forum, and keep with the same thread, rather then starting a new one at each step. It will make diagnoses much easier.
Go back to the original thread in the Electrical forum, I replied there.
