factory keyless entry
Old Jan 25, 2009 | 10:31 PM
blueoval5.4's Avatar
Does anyone know how to check if you have keyless entry from the factory. When i bought my 97 f150 4.6 xlt it only came with 1 key. The truck has power windows and locks. thanks
Old Jan 25, 2009 | 11:05 PM
fordmerc's Avatar
Ck to see if when you turn your key on, there is a "theft" light on the dash. You can also turn the key on and off four times I think it is and if the door locks lock then you have keyless entry.
Old Jan 27, 2009 | 08:27 PM
4Low4x4's Avatar
my 97 has it... but the kid (yes a 16 year old kid) that had the truck before me beat the living sh*t out of it. ive had to put almost a grand in it since i bought it and of course he lost all but one key im hoping i can go to the ford stealership and get a new one without having to give up an organ to medical research to pay for it
Old Jan 28, 2009 | 08:52 PM
fordmerc's Avatar
The 97 models did not have the computer chip in the key so you can go anywhere that cuts keys and have a copy made. I think wal mart does them for under $2.
Old Jan 28, 2009 | 08:59 PM
weshova's Avatar
until you go to walmart and they argue with you for an hour that ur truck has PATS and then u call them all dumba$$'s and leave
Old Jan 28, 2009 | 09:15 PM
RayD's Avatar
Cycle the key 8 times quickly ending in the on position. (I think there's a time limit) If the door locks cycle you have keyless entry. That's also the process to program the remotes when/if you get them: cycle key 8 times, locks cycle then press a button on each remote you are programming. The locks will cycle each time you successfully program a remote. Then turn the key off, the locks should cycle again and you're done. BTW, if your truck has power windows, locks, etc, you probably have keyless entry.
Old Jan 28, 2009 | 09:22 PM
weshova's Avatar
will a dealer check that for free?? i tried the key cycling thing but couldn't get it to work, I have the lariat and have power everything, leather seats, its pretty much loaded so i would think it would have keyless entry
edit: or at least wired for it so it would be easy to install it??
Old Jan 28, 2009 | 09:51 PM
MATTIAM's Avatar
Its 9 times in 10 seconds ending in the on position, the locks will lock then unlock, push your remote clicker thingy and it should work. that is if you have power remote locks.
Old Jan 30, 2009 | 06:48 PM
RayD's Avatar
8 times.
Old Jan 30, 2009 | 07:51 PM
SkyBound85's Avatar
i have an antenna above my rear view mirror inside the truck which has 2 antennas coming out horizontally from a black box, and i think that's for my keyless. does yours have that?
Old Jan 31, 2009 | 10:49 AM
cH1rO420's Avatar
I had the same question!
SO I went down to FORD or as they say here Joeten Motors aka Napa.. So many *******ing names..
And I asked if they could check if they can install the remote and they just asked to see the vin number (on super cab door on mine, right of the drivers door). So they ran the vin and informed me that it could work.. Also gave me a price on the remote and to program it.. 100 + pfsh..... I needed actuators too, but I just wanted to ask for the vin too.
So yeah, the dealership, or FORD at least, could run the VIN and see if its equipped with the remote.
Or are you talking about the keypad????
Old Jan 31, 2009 | 10:51 AM
cH1rO420's Avatar
did you steal that out of an airplane and installed it in your ovrerhead console Maybe your truck is equipped with TV satellite?
Old Jan 31, 2009 | 11:08 AM
weshova's Avatar
thanx, yes i was talking about the remote fob, i really don't like keypads on the doors at all, honestly i've never seen a 98 with a keypad
Old Feb 2, 2009 | 02:51 PM
sknyfats
Guest
Posts: n/a
FYI - I'm a new F150 owner (2001 w/137k miles on it) and was given 1 key & 1 remote doohicky. You can look on ebay & find a ton of different people selling remotes - so, to get back to your original question - if you do the cycle thing (EIGHT times w/in 10 seconds) and your door locks do the up/down thing - then you DO have remote capability. I bought 2 remotes for $20 shipped off of someone on ebay and they worked like a charm. Simple to program. Now I need to get an extra key...worried about that. I know I can get blank for like $8 bucks - but believe only a dealership can program it since it has that little embedded chip thing in it. I imagine that'll cost me a few bucks...we shall see!
Old Feb 2, 2009 | 05:59 PM
RayD's Avatar
Yep, you have to have a dealer program the key. Or someone with a scan tool capable of PATS functions. Some of the better locksmiths are programming keys now, wouldn't hurt to compare their prices to dealers. BTW, once you have two or more programmed keys it's easy to program them yourself.
