What fits on a 17 X 7.5 rim?
Tires on my Exp. with 67m miles are due for replacing. The 00 2wd, 5.4L Eddie Bauer came with 275/60/17 tires mounted on 17x7.5 rims. While I don't do much off highway I do need more clearance than this truck currently has. Will the 275/70 or 275 or 285/75 tires fit properly on these rims? I don't do any towing with the truck so loss of torque will not be an issue since the 5.4 seems to have plenty of pep, but realize that my speedo will be off quite a bit if I should go to 275 or 285/75 tires.
Thanks,
Walt
Thanks,
Walt
ok lemme try to put this so that i understand it also..lol j/k....i have the 17 x 7.5 wheels also......with 265/75 x 17 tires.....basically the 265 number is the height of the tire.....so cross reference it equals 31......now the 75 is the width of the tire.....which is 10.50 inches......and the 17 is self explanitory.....so in reality the 265/75 x 17 is a 31/10.50 17 tire.a 285 tire equals out to be a 32.so yes u can put a 285/75 17 on these wheels......along with the 275"s
Incorrect. 265 is the width in mm (265mm=10.4"). 75 (aka the "series") is the ratio (in percent) of the width of the tire to the sidewall height. So a 265/75 tire would have a sidewall height of 75% of 265mm, or 199mm (7.8 inches). The last number is the rim diameter.
So, in this example, a 265/75-17 tire would be a ((17 inch*25.4mm/inch)+(2*199mm))= 32.7" diameter tire, which is 10.4" wide, mounted on a 17" rim.
This all assumes the tire is mounted on a rim which is near the center of the manufacturer's recommended width range for that tire. Higher profile tires (eg 75 series) are more tolerant of rim width than lower profile tires (eg 45 series). Typically, for each +/- 0.5" in rim width the tire's sectional width changes +/- 0.2". Check with the manufacturer's or Tire Rack web sites for rim width specs for each tire.
Trying to figure out tire sizes can be frustrating.
I found a site that allows you to compare tire sizes. It will show you an over lap of the sidewall or tread. It will also show you the rim size in relation to the sidewall. Very cool.
It will even tell you how much your speedo will be off as you deviate from the first tire size you type in.
this sounds strange but the site is
www.miata.net/garage/tirecalc.html
enjoy.
enjoy.
