Safety Siping ?????
Safety Siping ?????
I recently purchased a new set of Path Finder SUV 255/70/16 tires. I was talked into have them "siped". For those who don't know what this is it is when they cut little slits in the tire to give them more traction as well as run cooler - or so Discount Tires claims.
From the heavy rains I have driven in these past 2 days I must say they will not let go of the road - excellent traction. The traction is so good it is sucking the crap out of my gas tank.
Has anyone ever heard of this and what are your feelings? It feels as though I am riding on 10 pounds of air in my tires. I am seriously debating whether or not trying to take them back.
They never mentioned seriously bad gas mileage with all the good things.
TommyRox in Flower Mound TX
www.mullenix.ws
www.mullenix.ws
From what I gather, many tire manufacturers are begining to invoke siping into their molds. I have called many Discount Tire stores and they claim that they have never heard of performance degradation from this process. I am going to watch my mileage on this new tank and post the results.
TommyRox
TommyRox
Siping should not cause the tire to wear prematurely, UNLESS it is a more offroad than onroad tire...then you are cutting out more rubber than it needs to get the appropriate mileage out of it. But for A/T or lesser tires (in terms of offroad...) it should improve traction....BUT not decrease mileage... hope this helps...
Most non-off road tires do come with siping from the factory, especially all weather tires. Have you checked to see where they set the tire pressure? Every set I've bought have always been set about 5 pounds below the max pressure. Your tires will ride a little smoother like that, but they are less efficient at rolling. If you fill them right to the max you should notice a little less friction and mileage will slightly improve.
Don't overfill though or they will wear prematurely.
Good luck,
Tim
Good luck,
Tim
