Any special brake fluid to use?
I don't think brand matters much, but you MUST use whatever DOT type that's listed on the reservoir. In fact, if it already hasn't been done, you might want to consider flushing out your system with fresh fluid. Best way is to use a vacuum bleeder. Using the old "step on the brake pedal" to bleed the brakes can damage the master cylinder.
My understanding of brake fluid is that DOT 3 and 4 are compatible. DOT 4 has higher temperture resistance than DOT 3. If it calls for DOT 3 you can use DOT 4 with no harm done. If it calls for DOT 4 you cannot use DOT 3 because of it's lower temp resistance. DOT 3 and 4 are compatible with antilock brakes. Either would suffice in our trucks. DOT 5 is not compatible with DOT 3 or 4 and should not be used in our trucks. It is a silicone base and is only to be used if specifically called for.
Ford DOT3 fluid is really good. Even though it's only DOT3, it has a higher boiling temp than most DOT4 fluids. 550F if I remember correctly. I use it in all of my vehicles, even the ones that see the track and such. It works better than any of the other stuff I have tried without spending $15 a bottle.
