Wheel/Tire Fitment Calculator
Old 10-17-2011, 07:00 PM
20064x4's Avatar
can i put beefy 35" on my stock rims?
Old 10-24-2011, 03:15 PM
EdgarF150's Avatar
20064x4,
I had 35" x 12.5 on my 2001 F150 with out lifting it, but you would need to do a little triming of your fender (the black plastic portion and add two to three sheet metal screws to the inside of the tire well towards the cab to push the tire well liner tight to cab frame). It took me less than an hour to do to both sides.
hope this helps, let me know.
Old 11-07-2011, 11:56 AM
Screwcaddy's Avatar
I have a 2006 F150 Lariat 2wd Supercrew with a 2" leveling kit on the front. Can I fit 305 45 24 tires? If so what offset should I have on 24x 9.5 rims? If needed I am looking to put Air ride on it if that will help me to lift a couple more inches if its needed. Please advises. Thanks
Old 11-07-2011, 12:03 PM
Welcome to the site! You will get a lot more veiws and help if you started a thread with your question. In the Tire and Wheel forum.
Old 11-07-2011, 03:46 PM
robotguy's Avatar
Tpms....
Hi, I'm new here and love reading your posts. I was wondering, is there a difference in the TPMS from '07 to '11 F150's? I found a great deal on a "new" set of chrome rims from an '07 F150 that were returned to the dealer for a warranty issue (a scratch which isn't noticeable). If I put these rims on my '11 truck will there be a programming issue with the TPMS??
Old 11-07-2011, 04:14 PM
The 2007 has a band sensor that mounts on the backside of the wheel. The 2011 has a sensor that is located in the valve stem.
BTW, welcome to the site!
Old 11-09-2011, 12:39 AM
robotguy's Avatar
Thanks! Are the band sensors from the '07 compaible with the '11? I'm thinking that I should save myself the headache and install the new valvestems. Sorry I don't want to sound like a dummy but the TPMS is new to me, the last new truck I bought was in 1995.....now I feel OLD!!
Old 11-09-2011, 07:09 PM
eric5oh's Avatar
The old sensors are not compatible. Those band sensors are a big PITA
Old 01-11-2012, 04:30 PM
Alex_4.2L's Avatar
I found this page which shows stock rim size but it only shows 2006 forward if that helps anyone
http://www.discountedwheelwarehouse...._Reference.cfm
Old 02-03-2012, 03:19 PM
B4Smith's Avatar
33x12.50 with minor rubbing but no way to tell 100 percent without looking at your truck
http://www.redrock4x4.com/tireconver...Name=Calculate
a great user friendly calculator
Old 02-03-2012, 05:18 PM
fine_style150's Avatar
sure you can
Old 05-29-2012, 10:40 AM
MookTastic's Avatar
I have a 2005 xlt screw 4x4, with stock 17 in. rims and no lift or level or nothing. Can I put 285/70-17's on them without any problems????
Old 05-29-2012, 12:13 PM
jerrybizzle's Avatar
No problem at all. Zero rubbing. That's what I originally had.
Old 05-30-2012, 07:50 PM
MookTastic's Avatar
Thanks jerrybizzle...Appreciate the help. Mine crappy bridgestones are starting to dry rot, so that finally made the wife convinced to let me get new ones. LOL!!! BF All Terrains here I come!!!
Old 06-11-2012, 08:02 PM
JDHOLC's Avatar
FX2 leveling...
fixin to level my wifes FX2, found a good tire size calulator so I have a vauge idea of what actual size the tire is.. thinkin of going with a 33 or 32in tire(265/70R18 or 275/65R18) any thoughts? she doesent want a "wish it was 4x4" look but she likes the height of my FX4 better... so will both of those fit ya think? and any insight with experience of which will look better?
Going to level my FX4 next, thinkin a 33/34 ish would work on it...
PS are the 6 F-150s ive owned the only ones that warp rotors like i have nothing else to do but take em to get machined every 6 months... ??
Last edited by JDHOLC; 06-11-2012 at 08:06 PM. Reason: doh! fergot year model.... 2010
Quick Reply: Wheel/Tire Fitment Calculator
