Anyone running nitrogen in tires
The guys at 4WP here told me thye have been experimenting with installing nitrogen instead of air. They say the benefits are: no cold spots, no loss of air due to temperature changes and it helps protect the temperature sensors because there is no water vapor in the nitrogen. Anybody tried it????
Not worth the money. It was all the craze when gas prices were high and it supposedly saved on gas. I don't buy into it. I filed it with respect to usefulness, right next to a TB spacer. About the same cost and similar help. Not being totally negative, the nitrogen in tires MIGHT (slightly) help those with extreme cold and maintaining air pressure (not an issue here in SW FL.
If they will offer it to you for free, go for it. But don't spend a penny for it.
What's this about temperature sensors in tires? Pressure sensors are surely there, but did the Fed's take that one step further?
Anyway, I wasnt planning on spending no more than about $5 a tire, If I see it helps maintain the pressure, I was going to put it in the tires on my boat and travel trailers. There is nothing worse than being in remote areas, having a low tire, and worrying about towing in 100 degree weather we have down here.
Maybe I am just being lazy. But if it does work why not do it. It could be cheap insurance against a blow out on a 2 lane highway in the middle of nowhere
I have nitrogen in my tires just cuz that it was the shop used to fill them
i do alot of driving 100 miles a day to and from work. so when the guy told me it helps to maintain tire pressure i said sure why not. i have 56000 miles on the OEM tire (second set) and they still have good rubber left on them.
since i had those tire put on with nitrogen i have only add air once to the front passenger.
i am sure you would get the same results if you mantain the air pressure no matter what you use to fill them
My tire shop does it for $7.00 a tire. You pay it one time with them. If you come back in and have tire work done, they refill them at no cost after the first time. I honestly think it is a scam. I am surprised at how many people do it.
I saw a diagram that explained pure nitrogen molecules are much larger than ambient air. So they are less susceptible to leaking and temp changes. Oh well. No nitrogen for me.
