00 f150 rim fitment ???
Hi guys i'm new to this site and it looks like many of you seem to be pretty familiar with theese trucks.Allright i have a 2000 f150 4x4 extended cab with the 5.4 I want to put centerline wolfer series rims on it. How does everyone think theese will look in 17x10 with a 4.500 backspacing and a offset -25.00mm?
My truck is solid silver The only thing i have done to it is chrome nerf bars and true duels w/flowmaster40s Soon it will have 35 12.50 w/ 6in fabtech lift from your reccomendations. how will those rims fit my truck as far as rubbing w/ that combo and wher do you think the tires will end up in relation to the fenders. It has the factory xlt flares on it i don't care if they stick out a little past fenders. Any help or comments will be greatly appreciated any pics with similar wheel would also help thanks
Thanks Wandell, is your offset -25.00mm? I think your truck looks awesome so i guss i will just order a BL with the rims also and run 33s or whatever is equal 305 ?? 17. Can i do the BL in a weekend? I did one on a 90 z71 in a day. Do you get any rubbing w/ 10in rim w/ wheels turned when you had 33s Does the PA kit come w/ rear bumper relocation brackets?Have you seen these centerline wolfer rims on our gen fords? I want mine to look tough w/out to much bling and i haven't seen them before. Sorry about all the ???s but i don't want to mess up and be unhappy Wandell you are a great asset to this site and i think everyone appreciates it man
Thanks. Yes, my offset should be the same since the width and backspacing is the same. No, I didn't have any rubbing when I had 33's. I only had to trim a little bit of plastic off the front bumper's lower valance when I had the 33's on 16x10's at stock height. The PA kit comes with everything you need, including front and rear bumper reloacation brackets. The 97-03 Ford's are a little more complicated to install a body lift on than the 88-98 Chevy's. Mainly because the body bolt's on the Fords cab mount opisite from the Chevy's. You have to remove some interior trim and pull the carpet back a little bit to access the bolts in the cab. They bolt from the top on our trucks. If's you installed one on a Chevy, you can handle it because you know what to look for. It took me an entire weekend to install mine, basically working by myself. I've never seen those wheels on our truck but I think they would look sweet.
