2 or 4 Wheel ABS
If you have drums in the rear you dont have 4 wheel ABS
at any rate, even if you did have discs in the rear, the rear axle is "one channel" so its still only a three channel system instead of four channel.
I can explain the whole channel things when im less intoxicated.
My 97 had drums in the rear and 4wheel abs. Did that change in later years?
