Tire Pressure???
Tire Pressure???
I have LT285/65/18 Nitto Grapplers (load range E) on 18inch Moto 700's (on the tire it says 80 max psi with no recommended psi). Im currently running them at 35 psi becasue that is what the sticker says in the door frame, but i do get a small bulge in the side wall. Am i running these tires to low? I only use the truck as a day to day driver. What should I keep the psi at to have the best wear.
Originally Posted by 4GIVEN
I have about 55 psi and it seems to be doing very well. I know the door says 35 psi but like you said, it seems to have a pretty good sized bulge.
Originally Posted by 03expyeb
50-55 should be adequate(sp?)
Originally Posted by 05supercrew
Im running my TGs at 48 right now and might lower it to 45 psi but wont go lower then that. 35 is way to low. I have 325-60-18 and they are LT tires with a D range.
Originally Posted by kingfish51
As they are D range, I would suggest 45. I agree that 48 might be a bit high. If you decide to go lower than that, I wouldn't go any lower than about 40-42.
It says 35 on the door because the old tires were P series tires. You have load range E LT tires. Get them up to about 50. Then check for abnormal wear and raise or lower the pressure as needed. I would not go lower than about 46.
Originally Posted by Hash278
Would this apply for procomp xtreme a/t's size 325/50/20 the load range is still the same I'm just not sure if it would be different since the tires are different
