ok so my last wheel post...if i decided to get the mazzi hulks in 20x10...
what size tire would i need to get on my 05 kingranch 4x4 supercrew??? and will it rub with a 2" AS leveling kit?? i like the eagle knockoffs but im thinking of possible going with the real deal...only thing that im wondering is how far the 20x10 will stick out farther than the stock 18's....thanks
Originally Posted by K1NGoftheRanch
also if they do stick farther out will it mess up my paint (rocks and stuff....my truck is black)?? thanks again i appreciate it
I'd re-think it if it were my truck.
Originally Posted by wandell
I'd try to find a 9 inch wide wheel with 5.5 or 6 inches of backspacing if you don't want the tires sticking out too far.
ok after much searching i think i have come to a conclusion on a wheel...of course the one i originally started with...the moto metal 951 20x9 with 6.18 backspacing...again these are going on a 2005 Kingranch supercrew 4x4...i will be adding a 2" Autospring leveling kit before these rims go on...with that in mind...what is the biggest tire i can clear without rubbing??? thanks again
Wandell, I think the 325/60/20 is a 35" tire, whereas the 325/60/18 is a 33" tire (at least that's what this tire calc says, http://www.miata.net/garage/tirecalc.html).
Are you saying a 33" tire is the largest tire that will fit without rubbing on a 20x9 rim with +30 offset? ('04 Lariat Screw 4x4 w 2" leveling kit)
Just want to be sure before I mail-order $2G of new tires and wheels. Thanks for the help.
