want 35's, what size lift do i need?
I know this gets asked a lot, but i cant seem to find the answer im looking for....i want to go with 35/12.50/18(mud grapplers) and possibly an 18x10(mazzi hulks) w/4.5 BS..........will this fit under a 4" lift or do i need the 6"? It will be goin on my 06 4x4 lariat 150 screw....Just want to know the best way to go and not rub ....i dont do much off roading basically goin for looks here, its not my daily driver so im not worried about the noisey tires, as long as i can still listen to the dvd/nav unit.....Thanks....
So wandell what would i need to get 38's under there?...Im still new here, and im not sure ive heard of the 5" RCD? Have heard the 6"fabtech was nice, but im still not sure which direction i want to go....im trying to keep the costs down as much as possible, but i know thats impossible...might as well spend a little more and get it right the first time...So tell me wandell, lets say i do want to squeeze some 38's on, what combo would i need, also wheel tire sizes if you have those handy, i have read your posts, and you seem to have a lot of experience at this, im still an amateaur at this...i have been doing muscle car restoration for about 7-years, and im trying to pick this truck stuff up....seems like theres a lot to learn....Hope u guys can help me out....
Be careful with the 10 inch wide wheels and the 4.5 inch back spacing. This will make the tire stick out about 3 inches from the fenderwells. This might not be a problem with the amount of lift you are talking about, but I have some rubbing issues with mine. I only have a 2 1/2 inch leveling kit on my '06 F150 Lariat 4X4 and I have 305/55/20 (33X12) mounted on 20X10 with 4.5 back spacing. To look at the truck from the side, there is plenty of room for the tires. They do stick out about 2-3 inches from the fenderwell. This is where the rubbing comes from. The wheels stick out far enough that when I turn sharp, the tires rub the inside of the fenderwell. I did a little trimming and I got it so I can live with it. It still rubs sometimes.
The 97-03's are completely different trucks than the 04-06's. On a 97-03, a 10 inch wide wheel with 4.5 inches of backspacing will put the edge of the tire just about even with the edge of the fenderflares. As dwypd stated, that same width and backspacing on a 04-06 will push the tires way outside the wheelwells.
