Pro Comp xterrain
Pro Comp xterrain
Does anyone know if Pro Comp makes a Xterrain tire in 33x12.5x17? And if not will 35x12.5x17 fit a 05 screw 4X4 with 2'' leveling kit. I would like to mount these on American Racing Mojove polished. Also any in put on these tires will help, I dont know anything about them. Thanks in advance.
personally I would go with a Nitto Terra Grappler
Nitto Terra Grappler LT295/70R17 33.3" O.D.
Nitto Terra Grappler. Nitto Tire expands its extreme performance tire line-up to encompass your off-pavement needs while maintaining superior on pavement ride and handling. Max. load 3195 lbs @ 65 PSI.
The Mickey Thompson Baja Radial MTX and the **** Cepek Radial FC II are both available in 33x12.50-17. The BFG AT KO and Toyo Open Country AT are both available 285/70-17 (33x11.50). I believe the new Pro Comp X Treme AT is available in 305/65-17 which is the same as a 33x12.50-17. They are a new tire that has only become available this year.
mt's and xterrains
the mud terrains are good tires. very comperable to the bfg mt. I have had both on f150's and i liked the procomps better. ride, balance, etc.. i got 50k miles on the pro comps and was counting when i got rid of the truck. my brother had xterrains on a powerstroke and they wore out in 25 to 30k miles. pulling and his driving habits were the problem.
