What size tire is correct?
I need to replace the tires on a '97 V6, 4x2 Flareside... it currently has LT245/75R16. The door post sticker specifies P235/70R16SL. The owner's manual has a warning statement, saying the tire size should NOT be increased. This vehicle is just used for commuting, ordinary driving... no off-road; only very light hauling. What would you astute gentlemen recommend for best fuel economy, ride, and handling? Keep the LT245/75 size or go back to the P235/70 original equipment size? What are the cost considerations between these sizes? My intent is to do only what is necessary to make this truck attractive to a potential buyer...
Thanks for your help...
Paul
Paul
speedometer compensation?
Thanks guys... do I need to change the speed sensor gear to get the correct reading of speed with the 245/75 tires? I did a comparison run on Discount Tire's site, comparing the 235/70 to the 245/75. It says that, with the 245/75 tires, when the speedometer is registering 65mph the actual vehicle speed is about 69mph. That 4mph might not seem like much but around my area it could mean the difference between a $200 fine & no ticket at all.
Is there a different gear available?
Thanks... Paul
Thanks... Paul
