trying to fit tires, torsion bars wont turn??
ehy guys i need your help! my tires just got here today! i got pro comp xtreme all terrain 325-60-r18 mounted on 18x9.5 eagles 102 with 4 5/8 backspacing. Today i tried to turn the torsion bars to give myself alittle room, and i couldent do it. I have never done this before so im not really sure what to do, but i put a 3 ton jack under the front of the car on the frame, jacked it up untill i got some daylight under the front tires, hopped under there and tried to tighten the screws and i couldetn turn them... do i need to grease them? do i need to jack it up higher? what is the deal? or will it just be really hard to get it going or something
i would appreciate hellp soon. i want these babbies to fit, but there too big right now!
thanks
thanks
fitment
LAXWARRIOR:
Tell me how the fit is without the Torsion bars being turned.
I am after the same tire and rim size for my NEW 05 F-150 SCREW 4X4.
I want to stuff the wheel wells and do no lift I am not really concerned about a little tire rub when turning but of course I dont want to have them rub all the time. For me I will be needing to be able to get in to the parking garages downtown now and then. (Cant do it in my Super Duty anymore) I was hoping to get 35" on 18" rims...Got any Pics ???
Chris In Miami
Chris In Miami
If you are trying this with a standard 3/8" socket setup, then forget it.... Even a 1/2" rachet will not give you enough leverage. You will need a 1/2" 'breaker bar' to turn that bolt. A breaker bar will be about 18" long (or more) and have no rachet mechanism that can fail.
Just to be a "MOMMY", I hope you put jack stands under the front end when you jacked it up and were torquing on those bolts!
good luck!
Mitch
good luck!
Mitch
Originally Posted by Johngs
I would not jack up the truck, just tighten the bars with the truck sitting on the ground. This way you can measure how much to adjust.
