Got Mine Today-BFG 285-65-18 AT
After reading about 30 posts I decided to go for it!!! These tires seem to work perfectly with a leveling kit and was exactly the look I was looking for!
They ride just a tad stiffer than the Rugged Trail's and are very quiet! Did not notice a power decrease at all!
I also just purchased a set. The ride is noticeably rougher than the Rugged Trail. The tire shop put 55lbs in each and the tire says max pressure 65lbs. Ford said to run the Rugged Trail at 35lbs.
Any body know what the max pressure is on the Rugged Trail?
Also, what is the lowest pressure that you can safely and economically run the A/T? Should the tire pressure also comform to Ford's recommendation of 35lbs?
Thanks for all replies.
