17x9 wheels and tire size
Will a 17x9" wheel fit on a 2005 f150 4x4 with no lift. found some pro comp that would look killer the bolt pattern is good backspacing is 4.75" What size tire should I go with? Lifting is not a option. will a 285 look too tight or would a 275 and stay with a 17x8. Dont like the look of a rim sticking out past the tire. Thanks for the help, I know I have asked a lot of questions, just dont want to buy the wrong stuff
If you plan NOT to lift/level your truck and don't like a wheel wider than a tire, rock the 8" wheel . Throw on some LT285/70R17's It'll be perfect. A 285 will work on a 9" but the tire will be a bit on the narrow side . I'll be getting 285s within the month and will be using my stock 17X7.5. BTW, the rim width range on a BFG A/T LT285/70R17 is 7.5 - 9.0 (similar with other mfg). Based on my experience in tires and your taste, the 285 on a 17X8 will be perfect.
Dan
Dan
I know you were thinking of going a differant direction than bfg's but bfg makes a 33 inch at ko that fits the 18 inch rim and is about the same width as the 285/70/17's. I do believe it is a 285/65/18. I too was thinking of going a differant direction than the bfg's next time arround. I was thinking of the titto's then I keep hearing they wear down fast. then I hear the toyos wear longer. then I go to there web sites and see they have the same wear rating. I like the looks of the nitto's better than the toyo's but then again I like the look of the bfg's too. I have heard mixed reviews of the bfg's but I like them. they seem to wear about average for a at tire for me. so all in all I haven't decided which direction I will go. I do know the bfg's are rated better in the snow and ice than the other two so I might just end up going back to the bfg's. that and I am thinking of going to a 18 inch rim and there 18 inch tire is not so darn wide.
