98 4.6 problems
98 4.6 problems
I have a 98 f150 with the 4.6. It has been running bad for about two month's. It would idle rough and have no power going up hills. So I changed the pvc valve egr pressure sensor. Ran OK for a few days then same thing but worst going up hills. I had to stop and pull off the two vacuum lines to the egr pressure sensor to make it up the hill. I re set the computer and changed the fuel filter. Two days ago I stopped at a stop sign my oil pressure dropped all the way down and came right back up so I stopped autozone got oil I opened the oil cap started adding it and half way through adding it the engine was really running rough and almost stalling. I closed the hood and limped back home with it sputtering and almost stalling. Got home removed the oil cap again the engine started to stall it's sucking air into the oil cap so I took the pvc out and that same thing sucking a huge amount of air through the pipe. Any ideas here I need this truck it's my only transport. Thank you
