2001 f150 5.4 miss
Old 10-16-2016, 02:54 PM
ymurf's Avatar
2001 f150 5.4 miss
I think I have a bad coil from what I been reading. In over drive under normal cruising speed sometimes it bucks and jumps unless I mash on the gas. Now the miss is noticeable even not in overdrive.I can rev engine and feel it. I have no check engine light yet. will a scanner still tell me which coil is bad if there is a bad one? How can I tell which one it is?
Old 10-16-2016, 03:50 PM
1972-2003f150's Avatar
Have you checked for codes? Your truck should throw a code which should tell you if there's a misfire and which cylinder or cylinders are guilty
Old 10-16-2016, 04:39 PM
projectSHO89's Avatar
It will post a fault code ONLY when it gets severe enough to go over a calibrated threshold.
Mild misfires must be diagnosed by looking at the Mode $06 misfire data with an appropriate scan tool.
Old 10-16-2016, 06:33 PM
ymurf's Avatar
Had my buddy hook his scanner up to it and it shows misfire on cylinder #3. I assume that's the culprit.
Old 10-16-2016, 07:10 PM
And I've learned something new today.
I am assuming by appropriate scan tool you mean something better than an Autozone cheapy? What do you recommend personally?
I see the OP got a result of cylinder #3 misfire, what would the next move be? Testing the coil for resistance?
Old 10-16-2016, 08:08 PM
glc is offline
Next step would be to change all the spark plugs if they have more than 60k on them - I'd at least pull #3 and look at it, replace the coil. Resistance testing is meaningless.
Old 10-16-2016, 08:14 PM
ymurf's Avatar
I bought plugs today and am going to pick up a coil after work tomorrow.
Old 10-16-2016, 08:55 PM
glc is offline
I hope you bought MOTORCRAFT plugs - torque them to 28 ft/lb and do not use antiseize. Use dielectric grease inside the coil boot.
Old 10-16-2016, 11:17 PM
ymurf's Avatar
I did buy motorcraft plugs. I don't want to use anti seize? Thought I was supposed to?
Old 10-16-2016, 11:40 PM
Roadie's Avatar
The standard recommendation now is to not use antiseize to help prevent them from blowing out because there are only about 4 threads holding the plugs in.
However, when I replaced my 02 5.4 plugs at 119k miles, I did use anti-seize. It now has 142k on it with no issues. I plan to go back and check to make sure they are still tight but I haven't yet.
Old 10-17-2016, 10:04 AM
glc is offline
Old 10-28-2016, 08:58 AM
thegeoguy's Avatar
#3 sparkplug
I had the same issue a couple years ago, it was a blown sparkplug on the #3 cylinder.
One Helicoil and new spark plug later and I was up and running.
Old 10-28-2016, 10:17 AM
glc is offline
You are lucky the helicoil is still working - the only 2 inserts that last are Timesert and Lock N Stitch.
Old 10-28-2016, 12:31 PM
Fully half of the inquiries for renting my Timesert kit have come from guys with a newly blown Helicoil, Dorman, Save-a-thread, etc and similar $30-40 "repairs".
That tells me all I need to know about them.
Quick Reply: 2001 f150 5.4 miss
