P0406 code help needed
My 2002 F-150 5.4L V8 Check Engine light is on and displaying P0406 code. Completely new territory for me, so checked on-line and found one source that advises checking the EGR Vacuum Regulator, EGR Valve and DPFE Sensor.
I replaced the DPFE with a non-Motorcraft part one week ago when I broke off one of the plastic inlets fiddling with a COP. Could it possibly have gone bad already?
Also read that a vacuum leak might be the culprit. Any advice on how to approach this P0406 troubleshooting process is much appreciated.
Any symptoms beside the code?
Let's see...
Whenever chasing a code, imagine there is no code.
Is the Truck doing anything else like surging or a high idle? a bad COP will give you a stumble... If you Rev it in park does it come back down to idle really slow?
If it's not doing that then I'd check the connections to the DPFE with a multimeter (if you have one) in case the connector went bad (you can cut a new one in pretty easy) and I'd check if a vacuum hose got cracked while you where in there.
But DPFE's tend to be buggy, so I wouldn't be too amazed if you got a bum one. Who was the source of the part? I've been sent bad MAF's, etc. from online stores.
Hope this helps
Hope this helps
Last edited by ParamountAuto; 01-19-2016 at 04:24 PM. Reason: My first response was unclear
Noted, glc! Yeah, not knowing any better, I bagged an aftermarket one for, ahem, 35 bucks...Guess I got what I paid for! On my way to Amazon... Thanks, man. BTW, I just did a vacuum test on my ERG valve and it both held vacuum and started to stall out the engine when vacuum was applied, so I'm assuming it's OK and the throttle body ERG ports are clear as well...
I did get DTC P0406 and the throttle body EGR ports were plugged solid. Also your comment Another example of misplaced enthusiasm in trying to be helpful from a new arrival is uncalled for. I was only sharing the problem I had. Also I have been a Certififed Technician for over 20 years and currently Shop Foreman for the lst 5 years. So I do have a clue. Thanks and have a wonderful day
