'08 F150 5.4L 76K miles needs new engine already?
So I took my '08 F150 5.4L (76k miles) in to my mechanic today because I had self diagnosed the VCT issue with my engine knocking/bucking when slowing down under 1000 RPM. So a little while after dropping it off, my mechanic calls me and says I need a new engine. According to him my engine code was reading as the VCT but he also talked with Japser engines about the issue and they told him it needed a new engine because the engine has some serious design flaws. They said (Jasper) that the 5.4L engine from day one has been starved for oil throughout the entire engine. Evidently the oil pump system is poorly engineered-so much so that they won't warranty the new engine unless you also put in their new oil pump system. The concern is that my engine is worn out because it hasn't gotten enough oil in the system. I want to point out that this is what they say, but neither my mechanic nor Jasper has actually looked inside the engine to see how much wear is actually inside the engine.
So the solution is a new (not remanufactured) $8100 Japser engine which supposedly has 40 fixes to it. I asked my mechanic how much would it be just to replace the VCT's, as it seems many people have had good luck, but my mechanic wants a little north of $600 and I don't really want to spend that much to find out I still need a new engine.
It's also hard to drop a whole new engine in when I read posts like this (http://www.f150forum.com/f4/final-re...-sound-141266/) that says a new engine is not always necessary. I trust my mechanic, but considering no one has actually looked in the engine to make sure it really needs to be replaced and it's Jasper who's tell him to replace it, I am a little less trusting right now.
So I do have another guy who can work on the truck for possibly less money and maybe save this engine, but I am trying to figure out if I would just be throwing money down the drain at this point. If it were an '06 or older I would try replacing the VCT's myself, but it seems to be pretty involved to remove the valve cover and I don't have that much experience.
Does anyone have any suggestions? Is it worth trying to have someone open it up and see what's bad or should I just bite the bullet and spend the $8100 (it would have a 3 year warranty which is a plus...but that's about the only plus.)
My initial thoughts are yer mechanic has lost his mind. But I don't have the truck in front of me either. The 5.4 can be an extremely long life engine. There is a website called The Million Mile Van and it had the 2V 5.4 in it and yes, it went well over 1 million miles and on the cheapest oil the guy could find. Changed it religiously too, like when he thought about or every 10-15000 miles. I'm assuming you are asking about the VCT solenoids. If you can change a tire, you can change them yourself. It's not rocket science. Here's a vid how to do it. I'd certainly try changing them before spending 8 grand on this truck. Frankly, I wouldn't fix the truck if the VCT solenoids doesn't do it. I'd trade it in considering your truck is probably paid for and add another 8 grand to it would leave you a small payment.
1994-2015 Ford F150 5.4L & 4.6L VCT Solenoid Replacement - YouTube
I am almost leaning towards having this other guy start into the VCT's and while he's in there take a look at the phasers, tensioners, etc. and if they look bad, go ahead and do them and the oil pump (with the new oil pump that has the cast iron backer plate.)
I actually started researching this afternoon about trading it in. My issue is I am not sure I would get all that much money for it. KBB says $13.5k dealer trade in, but I doubt they would give me anywhere near that much if they knew the engine was having issues.
It is. However, it's supposedly a new engine and not a remanufactured one, which makes a little more sense. Plus, that's labor/tax/everything.
I think I am leaning towards having this other guy start to tear into it and replacing what needs to be replaced. If the motor is in really bad shape I'll have a few hundred in labor costs, but at least I'll know I actually need a new motor instead of being told I do just because of a VCT code coming up. But if I do this, should I just go ahead and put lockouts in the sucker?
If you bought it used, you have no idea how well it was maintained. The 5.4 3V needs meticulous maintenance to avoid these issues.
I'd pull the valve covers, if you see a lot of sludge, get a new engine.
By the way - the Jasper is not a "new" engine - it is a reman. The only way to get a "new" engine is a crate motor from Ford, if they even have any left.
They don't make them new! Jasper is a Ford supplier of re-manufactured engines! They supply ford with rebuilds because even the dealers cant get new engines. There out of production. Who knows maybe Jasper stock piled a bunch of blocks. I doubt it though.
My mechanic said it was actually a new motor, but I am really starting to wonder if it's not a rebuild with all their updates added on to it. For $8100 I certainly wouldn't be happy with a rebuild. But it doesn't matter as with parts and labor, I found a mechanic that'll do it for under $2k ($700 labor plus parts.)
