need help!!
Old 10-12-2015, 05:04 PM
bone1376's Avatar
need help!!
Hello all, I am new to this forum and I am in need of help. I have a 1997 f150 with the 4.6l and I got a code cylinder #5 misfire, I changed plugs and coil pack. Took care of the problem for two weeks. Yesterday I got the same code. So why would I get the code again and what would cause it? Is there something I am overlooking? Any help is greatly appreciated, thank you.
Old 10-13-2015, 10:43 AM
glc is offline
Did you change the plug wires?
Old 10-13-2015, 07:56 PM
bone1376's Avatar
Not yet, just got new plugs and wires today. Going to change them and coil pack tomorrow
Old 10-13-2015, 08:06 PM
SSGT_B's Avatar
Switch the coil pack to another cyl and see if the misfire changes. If not then you have deeper issues. If so, buy new coil pack
Old 10-13-2015, 08:36 PM
glc is offline
The coil packs seldom go bad - but wires and plugs sure do.
I hope you got MOTORCRAFT plugs and wires, these engines don't like aftermarket. Torque the plugs to 28 ft/lb and use dielectric grease.
Sarge, that engine has 2 coil packs, each handling 4 cylinders. You are thinking COP (coil on plug) which are *not* "coil packs".
Old 10-13-2015, 08:38 PM
SSGT_B's Avatar
Thought it had 8 like my vette lol. That's how we would figure out a bad one on them.
Carry on, I was never here
Old 10-14-2015, 07:10 PM
bone1376's Avatar
Could it be a bad injector causing the misfire code?
Old 10-14-2015, 07:24 PM
SSGT_B's Avatar
Are there 8? If so change it to a different cylinder and see if the code follows it
Old 10-14-2015, 08:10 PM
Roadie's Avatar
Yes
Old 10-15-2015, 12:25 AM
ParnAZ's Avatar
FWIW the number 5 plug is right next to the thermostat housing/elbow. Check for moisture you may have a leaky o-ring that might not show up until under pressure.
Quick Reply: need help!!
