4.6 hard to start
Old 04-19-2014, 01:15 AM
20064.6's Avatar
4.6 hard to start
I have a 2006 STX with 4.6 after sitting it is hard to start, it will turnover after attempting this three to five times it will start. I had a guy check it out and said the throttle body was bad ? It is doing the same thing again after a couple days does anyone have any ideas, the fule pump appears to be working fine
Old 04-19-2014, 01:23 AM
jgger's Avatar
2Guesses. 1 Fuel pump driver module. 2 Stuck open egr valve.
Have you had the fuel pressure checked?
When was the last time the fuel filter was changed?
Old 04-19-2014, 01:28 AM
20064.6's Avatar
Fuel filter changed about month ago, I assume the mechanic checked fuel pressure ? when they changed the throttle body, I figured the fuel pump was ok because it will start along and along with no problems, and it does start ok when it is hot
Old 04-19-2014, 02:05 AM
jgger's Avatar
The fuel pump may be OK. The fuel Pump Driver Module (FPDM) may be going bad. It is located on top of the cross member above the spare tire. They can do goofy things when they start to go bad. Put FPDM in the search box and see if that looks like your issue.
Bad plugs will make it hard starting too. What does the maintenance history look like, and how many miles?
Old 04-19-2014, 02:43 AM
20064.6's Avatar
The plugs were changed about 8 months ago motor craft, truck has 130,000 miles
Old 04-19-2014, 09:44 AM
Simply67X's Avatar
FPR symptoms: hard starting, occasional stall, surge in rpm or a sudden drop (near stall).
Fuel pressure regulators do go bad...also agree with jgger's ideas. Good luck!
Old 04-19-2014, 10:23 AM
Roadie's Avatar
Isn't there a temperature sensor that tells the PCM to enrich the fuel mixture when cold? Could this be the problem?
Old 04-19-2014, 10:35 AM
glc is offline
There is no FPR on a 06, it uses a FPDM instead.
No fuel pressure test port, the only way to check it is with a OBD2 scan tool.
Old 04-19-2014, 07:21 PM
20064.6's Avatar
Another thing it will do when turning it over you can depress the gas pedal and it will help it start up, this after noon I let it turnover until it started took about 5-8 seconds and when it starts it takes a second for it to rev up.
Old 04-19-2014, 10:49 PM
Simply67X's Avatar
Ahhh...thanks. Was not aware.
Old 04-20-2014, 02:06 AM
20064.6's Avatar
Old 04-27-2014, 09:52 PM
20064.6's Avatar
Just to let you guys know the problem was bad fuel injector on the #6 cylinder, replaced injector starts up and runs like new truck.
The following users liked this post:
Quick Reply: 4.6 hard to start
