Need help.. No power to the pump
98 f150 5.4 4x4
Will turn over but won't start. Put a brand new complete fuel pump but won't kick on. Tested the wires to the pump And no power. The relay is good the fuse is good. Relay clicks on and gets power but no power to the fuse. I checked the fuel shut off switch and that's still down and ok. Removed the line from the fuel filter and no fuel coming out upon turning the ignition on. Not sure what else to do or check please help. Thanks.
Heading back to the pick a part tomorrow since they just got in the same truck the other day. Gonna grad that pcm and will also grab the cut off switch. And idea in how to remove the pcm? When removing the kicker panel on the passenger side I noticed a blue box their ( which I'm unsure what that is for ) and to the left of that closest to the fire wall is a silver box which I'm guessing that is the pcm?
on
If you don't have power to the fuse that is supposed to supply the fuel pump circuit, you've wasted all your time and money trying to "fix" something that doesn't have any power. Kind of like replacing all the parts in a TV set that doesn't work after already finding out that the wall outlet that it's plugged into isn't supplying any power.
The 98 does NOT have any factory security system that disables a fuel pump.
If the fuel pump relay energizes for about 2 seconds when the key is first turned to RUN from OFF, the PCM is doing what it's supposed to do.
on
Ignore the smaller relay box, it's for your trailer lighting.
Since you have proven that F19 is supplying power, how have you proven that the fuel pump relay is energizing and is good?
The fuel pump power circuit is very simple: Power from F19 is on the normally open contact of the relay all the time. When the PCM powers up, it is programmed to energize the fuel pump relay for about two seconds (ONLY!) to pressurize the lines. When the relay is energized, it routes power from F19 to the inertia switch. If the switch is properly set, it will rout that power to the fuel pump and, barring any other circuit faults, the fuel pump will have its operating power and will operate.
You can hear the relay Click on when you turn the key and hear it switch off. I also bought a new relay and put that in and still no power to the pump. I have the fuel line disconnected from the fuel filter so I'll know if it's priming or pumping fuel. I checked to make sure the fuel switch is still down which it is.
