97 f250 5.4 v8 light duty
I Have a 97 f250 5.4 v8 . It has 325 000k. It runs rough in park at low rpm's and has all it's power but when I put it in any gear and try to drive it there's next to no power at all I can floor it and go very slow, I just replace all new plugs,coils,fuel injectors,intake,all gaskets,a few vacuum lines, throttle position sensor,mass air flow sensor,throttle body, PVC valve and I don't know what else to do, it's completely gutless unless it's in neutral or park. PLEASE HELP ME!
I have a 97 ford f250 that I had parked over night and the next day ran rough and no horse power at all so I went and replaced the intake gaskets, coils,plugs,vacuum lines,fuel pump, fuel filter,fuel injectors, and now it has power when you step on the gas but it looses it after a few seconds and the comes right back it will not run in the cold it just cranks and back fires, when it does run it's constantly backfiring. What could cause this? That's all that I did to it so far
Parts stores should have compression testers in their tool loaner kits. They aren't expensive to buy:
http://www.harborfreight.com/8-piece...kit-69885.html
