04 4.6 Where's the PCV valve? Thanks
The front of the truck is the same as the front of yourself lol - Look staight ahead, what's R/L ? The vehicle has a front and back, so the same applies.
Now you know what most people know lol.
BTW - The 04 heated PCV would be on the drivers side back by the firewall.
Gotcha
Why is the PCV valve heated?
The replacement one (Standard #V341) is just a normal rattler type.
Is the mount heated?
FYI, yest. I changed oil, Cleaned the MAF sensor,discovered that the throttle body was covered with an oily coating on the inside. I opened the butterfly and the top was coated with blackness. A good deusching with Gumout carb cleaner helped. I thought about removing it to clean it, but took the lazy way out.
I also replaced the fuel filter and serp belt.
I've got the plugs and di-elec grease but that (and radiator flushing) are going to be another day.
Thanks for the help.
Didn't all drive by wire models get upgraded PCV systems? - I thought ?
mjb should know be be able to tell us by now lol.
This is probably a 3 valve diagram, I don't have it marked. Yea, I thought the 04's -4six and 5four "wire" set ups were the same.. ??
I won't be getting back to the truck maintenance till next Sat.
I'll post any findings....
Thanks again.
GLC, I don't have a K&N....And what's wrong with using the "Standard" PCV valve?
FWIW,-The trucks running great after the MAF and throttle cleaning
Thanks again.
