Do you have to remove the fuel rail to change COPs on 5.4L?
you dont have to but it is so much easier. all you have to do is unbolt the two bolts up top and then lift off they move out the way alittle bit. i was scared to do it but it is easy. just make sure the o rings stay on the fuel injector or you will find out the hard way when you try to install them and the orings are in the rail still it wont go on. just fish then out put them back on the rail if there not split and lube them up with some oil and your good to go.
Screw that, It's just 4 8mm bolts / lay some rags down and pull the rail up - flip it right on top of the manifold. You can do it with it loose on the drivers side, but when you install new COP's , you have to make sure that the plug boots are centered on the plugs before you twist back and forth to get them seated on the right. That can be a b^tch with the rail in the way on most of them and it's so simple to relocate temporarily.
Also, it's easier to strip a coil bolt with the rail in the way. When there removed - It's allot easier sealing the plug/boot chambers off with di-electric grease or #8 - #10 O-Rings + Grease (however you do it).
But the answer to your question is - No, you don't have to remove it.
I've done it before without the rail being removed on a 5.4L. The tricky one is #6 or #7 (can't recall, it's one of those two.) - It's a real PITA getting on the coil bolt w/socket. I've heard it's easier on the 4.6L.
I screwed up the boot when installing a new coil on #4 once - I couldn't get enough leverage or the right angle when trying to twist it on the plug - The boot kinked/folded. I didn't realize it until it missed when I fired it up - Had to dig into again that time
It's personal preference really - I like it easy..
I just greased mine up really good with the Dielec. grease and they went right on. Plus I had the motoblue connectors which are solid metal of some type, they don't bend, they go on positive and snap in very nicely. You know when they are connected. I highly recommend them! Very nice compared to that stock spring crap!
Guys, how do ya'll keep from killing your back changing out these and plugs? 'Specially the back ones. Standing on the front wheel, leaning in and over, having to use reading glasses(for us older guys ) gives my old back and knees some serious pain.
Techniques? Always looking for a better way.
on
1 Post
OR - You could just jack up the rear real fast , that works for me -
BTW - I borrowed grizzstangs milk crate, but the damn thing would slide out every freakin time I leaned over the motor!!! Don't you hate that!! ????? - Pull the wheel and drop her down on blocks - If you have a compressor, it's not a big deal.
