What sensor is this?
I have 98, 4.6l SC, the sensor is right next to the A/C compressor, attached to a piece of metal attached to the block. What is that for and can it be moved slightly towards the back of the engine. I replaced the compressor with an idler wheel and it just touches it. thanks.
HI!... A bit off topic but from what I understand you eliminated your A/C compressor, right?
If so you didn't need a idler for the deletion. You just use a shorter belt and a non A/C belt tensioner which pulls the belt in the opposite direction. Can you post a pic of the sensor your talking about?
Here's my A/C delete :
My PC/ED DVD isn't working - Heres one that came up online for a 4.6L -
http://autorepair.about.com/library/...bl732a-lib.htm
Originally Posted by JMC
Try; «Section 303-14: ELECTRONIC ENGINE CONTROLS» Removal and Installation Crankshaft Position (CKP) Sensor 4.6L and 5.4L
JMC
JMC
Item Part Number Description
1 9F715 Idle Air Control Valve— (IAC) — 4.2L Vehicle
2 9F715 Idle Air Control Valve— (IAC) — 4.6L, 5.4L
3 — Cylinder Head Temperature (CHT) Sensor — 4.6L, 5.4L
4 (ECT) — 4.2L, 4.6L12A648 Engine Coolant Temperature Sensor
5 (TP)9B989 Throttle Position Sensor
6 — Fuel Pressure Sensor
7 6C315 Crankshaft Position Sensor— (CKP) — 4.2L Vehicle
8 6C315 Crankshaft Position Sensor— (CKP) — 4.6L, 5.4L
9 6B288 Camshaft Position Sensor— (CMP) — 4.2L
10 6B288 Camshaft Position Sensor— (CMP) — 4.6L, 5.4L
11 12A362 Camshaft Synchronizer— — 4.2L
12 12A699 Knock Sensor— (KS) 4.6L
13 12A699 Knock Sensor— (KS) — 4.2L
thanks yes that is what it is.
It was so close to the compressor I thought it was the elec. to the compressor and took it off. The engine wouldn't start, I hooked it back up. But on the idler pulley it touches. I was wondering if it could be twisted back a bit.
What I ended up doing was taking sandpaper and holding it up, I only needed about a credit card with to make the clearance.
thanks for the help.
