Engine randomly shuts off
I have a 2001, 5.4L F150 and it's been shuting off on me while driving. It drives just fine but last weekend the truck keep dying. The engine will shut off and I can turn it back on and drive another mile then it shuts off again. After sitting for the day it will run just fine. I took it to my buddies shop and he ran every test possible and he couldn't find anything wrong. Does anyone have any suggestions?
Thanks!
Thanks!
I haven't changed the fuel filter but when I took it to the shop my friend said he checked the fuel pressure and it was ok. He said if the pressure was ok then the fuel filter and pump are working. Is this correct? I'm kind of mechanichaly declined.
Jbrew - can you please explain to me how or where the relays are to swap? I've never done that before.
Thanks for the help guys.
The relays are on the right in my truck - under the hood in the Power Distribution Box.
Yours are in a different location prolly , you have to look for them.
See the black box like deals on the right that all have the same part numbers.
Those are relays that act as a switch sort of. I would try swapping those around , but find the fuel pump relay. That little book that comes with the truck in the glove compartment has your fuse and relay layout.
If not - go to Motorcraft.com and download your manual..
Also , you could have a buggy computer/PCM - it happends.
Disconnect the battery for 15 minutes and reboot (reconnect the battery , positive FIRST)
No warning lights came on at all and all gauges looked good as it shut off. The oil light came on while it shut off but I was told that's because the engine wasn't pumping oil while shuting off so the light came on. Either way I changed my oil after the first time and it shut off. My buddy hooked the truck up to his code reader thing and it didn't have anything stored in the memory.
Originally Posted by f150tucson
If I'm swaping the relays because one is bad, would it make something else not work because I'd just be putting the bad relay into something else?
Thanks!
Thanks!
Yeah , that's the Idea - That tells you it was the relay
Be sure to reboot it - Like I said , they do sh^t like that if the comp gets a little buggy - Sometimes Zapping the PRAM (parameters) is all it needs. Clearing the KAM , resting trans tables, fuel trims, etc.. Theres a very good chance that it might work itself out..
Is yours shutting off anytime? Like while sitting at a stoplight, driving away, and cruising?
Man I hope I don't have to buy that many parts trying to fix this.
Yes, it would shut off while sitting at a stop light or driving. It's only had two "episodes" of shutting off. Once last week and about two weeks before that. So it's not like it does it all the time. I ran it all week to work and back in the 110 degree Tucson heat and it runs fine. But when it would shut off on me. I'd wait a minute, start it back up then it would only drive about a mile before stoping again. Then it would drive fine the next day. Hopefully it's just a relay.
Read fast , yuh sound like a frog .. -
