Oil Leak?
Oil Leak?
I am a newbee here so forgive if I ask anything stupid. I have a 99 150 with 100k on it, it sits for weeks at a time cause I drive my Dodge Cummins for work.
Latley I have noticed a knock when first started in the morning and a oil leak has started in the last couple of weeks. It looks like it is coming from the rear right valve cover and runs down the bell housing.
Is there a common place these trucks leak from?
I am running 5w30 motorcraft synth. Is that why I hear the knock?
it is super common on your year 5.4.
I also have a 99 5.4 and thought I had the dreaded pass side head leak and it turned out I didn't! However, my intake manifold WAS leaking and it WAS leaking down the pass side onto the bell housing.
the moral of the story is make sure someone who really knows these engines checks it for you.
also some people including me have run with the leak for years with out problem.
as for the noise at start up what kind of oil filter are you using?
Originally Posted by chester8420
Well, you said it was leaking from around the rear right valve cover.... Before you go spend a lot of money on head gaskets, make SURE it isn't just a valve cover gasket!
Either way it's a job I don't have time for, I always have to keep two trucks cause one is always in need of repair! And now I'm in my buisy season with work and won't have a break until thanksgiving.
That has been the only problem with the ford though (other than the poor mpg's) the P.O. has already replaced the right rear coil pack due too the leaking heater hose and left a card in the glovebox that showed a few codes he had pulled and repaired. So I hope to keep this one for quite some time.
newleak
I also have a 1999 f-150 4x4 and have noticed new spots on the driveway.
I have 116,000 and the oil seems to be dropping from the oil lines in and out of the Filter which is near the driver headlamp.
also, Does using "Restore" oil addative shorten an oil filters life?
I also have sign of fresh oil underneath on the gromet (BlackPlug) on what I'm guessing in the bellhousing?
Bad sending unit?
Bad sending unit?
Sorry to hear about your troubles. I have had good service out of my Ford. It eats front rotors for breakfast, and you have to shut the engine off at the gas pump, or it will never fill up. But aside from that, it has been a good truck. And I USE it hard.
I've been a ford man all my life, my first truck was a 79 f100 I built from the ground up with a 351w and I still kick myself for selling it. But not a one of them did'nt have at least one little thing wrong with them, so I guess I should get used too it.
Bad sending unit?
Bad sending unit?
