Engine is knocking after detailing engine
Yesterday, I used Black Magic engine degreaser and water to clean my engine....2001 F-150 5.4. I drove my truck shortly after with no problems.
This morning on my way to work, I noticed that my engine was knocking. Most of the knocking is on acceleration at any speed. It does knock when idling but slightly.
Does anybody have any idea as to what happened and what can I do to fix?
ps: I did not cover anything as the instructions on the can said "no wrapping required".
This is a VERY common problem with these trucks. When you wet the cop's water gets between the spark plug and the boot, and it shorts out the spark plug. Drive at a steady missing speed until the check engine light illuminates. Then take the truck to autozone, and they will tell you which spark plug is at fault. Then take the COP off and the spark plug out, and dry them. It will probably fix it.
Don't ever wash your engine again, unless you want to be doing this again.
Wet spark plugs are ok. It is the coil on top of the plug that you do not want to get wet. If you do they will dry out but if they are cracked or old the water may get in deeply and cause misfires etc.
Remove any that you suspect are wet and dry them the best that you can. Use di-electric grease in the boots when you reinstall them to prevent future soakings. If they are cracked or damaged in any way replace them. You can use WD-40 sometimes to displace the moisture but remember it is a solvent and you should be careful about how much you use and where you spray it.
One more thing.
Norm,
Is it fairly easy to remove the coils for a close look? I am fairly mechanically inclined but I do not try to tackle certain jobs that I could have paid a mechanic shop $100.00 to do and would have save me a lot of time.
Thanks for you helpful info, I really appreciate it.
John
John
Unfortunately on our 2001 trucks they can be a pain in the a$$ to get out depending on which cylinder. The fuel rail is in the way. It is a tight squeeze and takes some patience and proper tools. It is definitely do-able however.
Just do a search on plug changes and you will find pages of instructions.
You could try compressed air first and blow around each plug and coil to remove any puddles in the plug wells. Sometimes they dry out on their own.
