Block Heater?
Block Heater?
Howdy ya'll
I was recently under my truck doing my 30,000 mile maintenance and I noticed a plug going into the driver's side of my engine (2002 4.6L) that looks like an orange extension cord. I'm assuming this is a block heater. I tried to trace it up, but couldn't. Not that I need a block heater down here in Texas, but if I wanted to use it, how do I go about doing so? Does the owner's manual show me this (I haven't looked yet)?
Sounds like a block heater... although the orange cord means it could be aftermarket? (my stock one was black). It usually goes to a freeze plug in the side of the block. They are recommended by Ford to use when -10F... you just plug it in for about a half hour or so before you start it. Alaska Dept of Environmental Conservation recommends using them at +20F and below to reduce emissions during cold startup.
HI!... Some of the ealier trucks came with orange cords, some with black. My "99" had a orange cord from the factory. We get cold winters up here in Canada. I used to keep mine plugged in all night. All it is, is like a heating element. Heats up the coolant a bit. Also helps it not to freeze if your in really cold climate and your antifreeze mixture is not up to snuff.
Hell, I plug mine in when its 35* outside. Just to reduce hard starts and warm-up time. One doesnt really do much. When I get this 4six out of here, the 5.4 I'm putting in is going to have two block heaters... Plug the cord into an outlet and listen for a steaming kettle sound from the engine bay. That'll mean you do indeed have a block heater.Most of us need extention cords cause our trucks are parked far away from a outlet, get the shortest, thickest cord you can. It helps the amperage draw and efficiency
on
1 Post
Thanks ya'll, but I am aware of why the block heater exists. My question is, how do I plug it in? I searched the owner's manual, and it doesn't mention a block heater anywhere in the entire thing. Do I just plug a regular extension cord into the end of it, or is there some special adapter or cord that I need to use? Also, after looking up under the truck, I still can't even see where the other end of the block heater cable is. It looks as if it ends up somewhere up under the airfilter. Can someone tell me where it is? Thanks in advance, and I appreciate all the help.
Reach through the lower airdam on the driver's side toward the foglight. It may be zipped tied behind the plastic panel. It will have a cap on the end to protect the plug. I installed a ford factory one on my truck and that's where the kit instructed me to route all the cable. Hope this helps.
