More Power?
Originally Posted by MmmBuckles
does anyone know a fairly inexpensive way to get a boost in power. ive got a '98 4.6L and its just not fast enough. any suggestions?
Later I installed underdrive pulleys and Electric Fans and to tell you the truth I couldn't tell if there was any real improvement in power or MPG from those two upgrades.
Again the Coil Pack Upgrade is a definate winner. I've heard that Accel Coil Packs are just as good as ,and some would say better than, the MSD Coil Packs.
Doug
I'm curious , How is it possible for coils(ignition spark) to increase HP.
I recently replaced the COP's system on my 98 along with upgraded 19 lb injectors(spray pattern upgrade)..I also installed a series 50 muffler.
Thing is I did this all at once and noticed a jump in HP , I just wonder what mod made the most difference out of the three I chose to do..If it was the coils , I don't understand how - spark, just ignites the fire.
I don't know, but it made a difference, and like I said it was only the coils.
The engine and original coil packs had around 190,000 miles when I replaced them. I later read somewhere that coils should be replaced every 50,000 miles.
I know with a Coil Pack system the HP Coils give you a hotter spark because of the Higher Voltage that they put out.
I know MSD makes a Ignition System for COPs. But I've no idea how they do it since it doesn't replace the COPs.
jbrew
If I were to guess, I'd assume that the COPs and Injectors made the most difference for you.
Doug
jbrew
Doug
Yeah , I didn't replace my COP's until I was at 185,000 miles on this 5.4L. Everthing I got came from a 4.6L Romeo Crown Vic motor. New parts, but he couldn't sell as new because they had been bolted to the crate motor.. I got the COP's , Injectors and harness for under $200 US - You sure can't beat that eBay price - no one even bid on this stuff. I needed the harness aswell , only way I could adapt the newer type 3 injectors, they used a different plug.
I figured it was a combination of the add ons together . Old COP's and CoilPacs loose there punch after awhile..
190k
jbrew
Doug
jbrew
Doug
