Size needed to change fuel filter.
Originally Posted by jbrew
How yuh been temp1? 3/8 - this one works well for me - gives yuh a little leverage -
I have one of those X or scissors type wrenches but I have nevered used it. I had good luck with the plastic ones but they got legs and are no where to be found.
I remember conversing with you in the past but I cant remember exactly what it was. Something with water in the oil maybe?
Originally Posted by Zaairman
3/8". When you're done with yours come do mine.
I also have to replace the battery as my original one is 7 years old and my truck takes about 5 seconds to start the last couple of weeks. It used to start right after I turned the key. I figure I would replace the fuel filter and the battery and see what happens.
The battery is a BTX 65-850. I figure I could not go wrong with 850 cold cranking amps but I did read that the plates are thinner and that the 850 is not as durable as the 65-650 (I dont know if this is true). Time will tell.
I ended up using the 5/16 end of the tool but I suppose the 3/8 works just as well. The secret seems to be to pull hard on the fuel line when the tool is inserted to pull it off of the fuel filter. Trying to push the connection off with the fuel filter tool was not working at all. I suppose I could have put a screwdriver between the filter and the fuel filter tool to add additional force but pulling the fuel line worked quite well.
I could barley blow air through the old filter with my mouth so I have a good feeling that my delayed starting problems were due to the fuel filter. I thought I was changing the filters every 15,000 miles but maybe I missed the last interval.
Gasoline spilled all over me of course and on the ground which I got to lie in also. I guess the only thing left to do is drive to Wal-mart and walk around the store with a lighter in my hand telling folks that Im feeling really bummed out. LOL
Just Kidding.
Just Kidding.
Originally Posted by temp1
Heh, maybe if the temperature is warmer where your at (LOL ). Its 32 here right now and I have to do this outside. Im not looking forward to it.
32 degrees? You big weeny. When you have to swap out a motor, you're outside in a driveway, and it's 30 below zero, then you'll know cold!
i have never had a battery hold up like this one.
Im hanging in there, Jbrew, thanks for asking.
I have the scissors as well - the walls are to thick on my pair which renders them useless for me.
We met after I gave my COP's a bath and couldn't figure out why they didn't work any longer lol - that was quite awhile ago
