can i clean my k&n air filter
Old 12-12-2006, 07:18 PM
korte500's Avatar
without buying their cleaner? soap and water?
Old 12-12-2006, 07:29 PM
Tsquared's Avatar
At the Ace Auto and O'reiley the small recharge kit runs $10
I suppose you could use a dishwashing liquid to ge the oil and crap out. You would need to rinse it very good to get all of the soap out. You would still need to re-oil it. It will be hard to find a light weight spray oil to re-treat the filter - spend the $10.
T
Old 12-12-2006, 07:40 PM
Narvous's Avatar
T
WD40
Old 12-12-2006, 08:18 PM
Wolf302's Avatar
I'm sure you could just clean it very thoroughly with something else, you just need to be careful what chemicals you use not to hurt/deteriorate the filter itself. Even if you can manage that, it probably wont be as clean as doin it the right way. It would be better to just get an air intake re-charge kit...any kind will probably do....doesn't have to be a K&N. Hope this helps.
Old 12-13-2006, 02:55 PM
GIJoeCam's Avatar
I used simple green in the kitchen sink for both of mine. Worked fine. I'd be leery of using WD-40 just because of how thin it is... you take a chance of it staying over-oiled when you reinstall it, and that oil can cause issues with the mass air flow sensor.
-Joe
Old 12-13-2006, 03:07 PM
Since you need the oil, just buy the kit. It serves several cleanings.
Old 12-13-2006, 03:55 PM
Narvous's Avatar
Y do you need to oil it anyway ?
Old 12-13-2006, 04:07 PM
They call it recharge. You need to wash all the dirt off that it has collected, then spray a light coat of the oil they use on it. The dirt sticks to the oil.
Old 12-13-2006, 04:19 PM
Narvous's Avatar
Then y dont the dirt get by other filters with no oil on them?
Old 12-13-2006, 04:30 PM
Are you talking about the stock paper type? They are thick. The K&N drop in is made of a woven material, lets more air through(at least theoretically). It needs the oil to catch the dirt. I have about 38,000 miles on mie, have cleaned it twice.
Old 12-13-2006, 05:15 PM
BLUE20004X4's Avatar
Myself, I use the kit just basically for the oil. I don't screw around with other stuff just for say so, it's cheap enough so I do it. You could use soap and water, especially dish soap and it should work fine. Then the oil, not too much so not to f up the MAF or something.
Old 12-14-2006, 10:50 AM
GIJoeCam's Avatar
Because other filters aren't designed to be oiled elements like a K&N. A dry K&N is just a rock-catcher. May as well use a piece of screen.
Old 12-14-2006, 06:22 PM
chester8420's Avatar
Because motorcraft filters have a tighter weave, and thereby can't let small particles through. They also have a very light coating of oil on them as well. And they work a lot better than a "napa/autozone/etc" brand dry filter.
Might want to think seriously about your K&N filter, especially if you stopped it up. If you're routinely in a lot of dirt/dust, I would suggest that you use a motorcraft filter. K&N's are good for catching bugs, leaves, and grass clippings, but don't do much for dirt. IMO.
Old 12-14-2006, 06:38 PM
Narvous's Avatar
But can as much air get in with a Motorcraft?
Old 12-14-2006, 06:39 PM
I've taken my air filter completely out, and it makes no difference in 0-60 times, or 1/4 mile times. And my filter is completely brown with dirt. (motorcrafts are white) I disconnected my muffler, and it made it slower.
Quick Reply: can i clean my k&n air filter
