5.4L service engine light on
Hi all,
I was hoping someone could help with my issue. I have a 2001 f150 5.4L with the service engine light on. Everything runs smooth and normal.
The error code for the service engine light is:
too lean bank #1
too lean bank #2
After turning off the truck and returning 5min later, it smells like fuel in the cab.
Fuel filter was just changed 7000 miles ago.
Im thinking maybe the oxygen sensors need to be changed. What else could be the problem with a 5.4L 2001 4x4 with 77000 miles? Has anyone seen an issue like this before?
Thanks for all the help and happy holidays everyone.
too lean bank #1
too lean bank #2
Inside the intake , heres a pic, it's behind the silencer(that webbed outer piece) spray some brake cleaner on it or Carb cleaner. Something that evaps fast. 30lbs of compressed air helps clean it the best. heres a pic -
Actually it's not visible in the pic, but it's in that bar thing that crosses the center and it has two little wires that are horizontel , you'll see what I mean when you look at yours yourself. Clean those reboot your PCM and you'll see a world of difference in performance if you haven't done this before.
You also access it opposite side of the openning in the pic - pull it off the truck and access thru filter side, shine a flashlite inside to reveal the MAF sensor.
Not sure how else to explain , others may chime in to do so if I overcomplicated it lol..
Good Luck!!
Good Luck!!
Originally Posted by projectSHO89
C'mon guys. you should know by know that this code combo is almost always the same - a vacuum leak. It's also almost always the exact same place - the PCV hose elbow.
It is NOT the O2 sensors.
It could be a MAF sensor, but 20 to 1 odds say "vacuum leak".
Steve
Steve
My next problem is, How do i get the service engine light off? I heard someone say drive 5 miles and it will reset. I just got done driving 10.9. I could disconnect the battery, or is there a better way? If I disconnect the battery, how long do I have to wait for the capacitors in the circuitry to lose its memory and wipe out the code?
Thanks all who replied with help.
Take care.
