Fumoto oil change valve
No way....IMHO you can keep those things (including the speed bleeders) in the package where they came from! Seen them in the 60's...same design & all it takes is 1 ooops to really srew up an engine !
I've been doing oil changes since I was a kid and never, ever, ever screwed up an oil pan -- unless it was already screwed up, and by then I would repair it and re-tap it (or that's the reason why I they wanted me to fix their car). Just take your time when putting that bolt back in. It ain't rocket science.
As for the speed bleeders. I'm impartial on them, because they work just like a regular bleeder valve, but with a ball bearing and spring. But it does make bleeding brakes a hell of a lot easier.
May I ask why are you having the dealer put it on? Why don't you just wait until you change the oil yourself? What's one more screw and unscrew on that oil pan?
Ditto - not a good idea for offroading obviously, but unless you run over curbs, huge speedbumps or stop signs there's not much to worry about. Got one on my Miata and it's been no problem... gonna get one for my onefiddy.
If you are concerned about it opening up this can be done: http://www.fumotousa.com/faq.htm I have one on both my vehicles for years..works great !!
Free oil change
I also figured that if they put the fumoto valve on, it would be much easier for me who has to lay on the garage floor when I do it. I had to use a piece of sheet metal with my last truck wedged under the drain plug or the oil dripped onto the skid plate and then dripped out a drain hole later and onto the garage floor. Once I did the first one, I then figured out how to keep that from happening on subsequent changes.
On my Ecoboost, since I have not yet had the oil changed, the valve removes all the unknowns that I would certainly learn as I do it for the first time.
For example, from reading here, I understand that I need to slightly loosen the oil filter so it drips slowly down into some collector and channels it into the oil drain pan. Since it is still too cold to go looking under the truck, I am looking for lessons learned so as to not reinvent the wheel.
I have had one installed for over two years and works great! You just flip the valve with your fingers and it drains smoothly. I liked it so much I put on on my wife´s car as well.
I buy them straight from the fumoto valve store, i think these are the original ones. plus they have a very good size chart and you can select the valve that matches your car model.
long or short nipple
