1997 shift issue when cold
Old 03-20-2016, 09:53 AM
zook's Avatar
I have a 1997 farm truck about 100k on the truck. 2wd v6 automatic od.
My issue is:
when its cold the tranny seems to drop out in between shifts. It feels like the truck is off, but when it up shifts away I go.
I do hear a winning noise so I dropped the pan to change the filter thinking the pan would be dirty. I was taken back by how clean the inside of the pan is.
Could this be a sensor? When the tranny warms up it shifts fine.
Love my chicken truck but I don't want to dump to much$ in to it.
Old 03-20-2016, 11:46 AM
zook's Avatar
I put the new filter in and changed the filter. I took it out for a test drive.
It seems the flutter at low speeds in between up shifts and down shift. That's the best way I can describe the issue.
Winning isn't not the tranny. It is in the belt drive end (not related to post)
Old 03-20-2016, 01:28 PM
glc is online now
Did you also drain the torque converter? If not you only got 1/3 of the old fluid out.
Old 03-20-2016, 01:35 PM
zook's Avatar
good point!
No I did not drain the torque. I,ll check to see if there is a drain plug
Old 03-21-2016, 07:47 AM
Darrin Burch's Avatar
Could this be ignition related?
D
Old 03-21-2016, 08:54 AM
zook's Avatar
Funny thing is that is just what I was thinking this morning driving to work. Maybe the coil pack?
Old 03-21-2016, 06:10 PM
zook's Avatar
I just changed out the coil pack and the truck shift smoothly!!!
As I understand it if the truck doesn't have full spark the torque lock-up engages and disengages causing the truck to sputter, giving it the feel of a bad shifting transmission.
Its been a good learning day.
Thanks for everyone's input !!!!!!!!!!!!!!!!
Quick Reply: 1997 shift issue when cold
