Have an f150 but do not know if is good to tow a car
Hello everyone... I new in this forum. I do not know a lot about trucks and I need your help guys..
I have a 2001 F-150 Lariat extended cab 4x4 V8 5.4 Triton. The differential said H9 i think is a 3.55LS gears.
My intention is tow a car one's a week 40 miles by using the freeway, but I do not know if this truck will be good for that. I work fixing cars and this will be the only way I can get them to my place of work. Already has 220.xxx miles. I am also planning using a car dolly, not a ramp.
I would like to know what is the max tow loading for this truck and if I will be able to do it without killing my machine. I am short of cash and that is why i do not buy a V10.
If u need more info please let me know
You should be fine. Most cars plus dolly is not going to weigh in m ore than about 4000lbs. As you are using a dolly, tongue weight should not hit the limit of 500lbs (limit without a WD hitch). Only thing to be sure of is the shape of the transmission. Serviced? May have to tow with OD locked out.
The subject is towing so it has to be the transmission fluid. Heat is the biggest killer of an automatic transmission. I have a gauge on my trans fluid output line before it enters the radiator and it reads 150 degrees.
You can do what I have done so far. I have installed an external oil cooler and a remote oil filter where I can use a larger filter and have pressure/temperature gauges monitoring the system. I did all the labor and saved a ton of money. Helping build race cars sure helped. The radiator has been replaced also to keep things cool with the A/C on. This is getting ready for the engine rebuild where the extra ponies are gonna make more heat. There's a 4 link rear suspension not leaf springs. The coilovers are triple adjustable to tune in perfect to driving conditions. Airbags for overload conditions to.
Is there any advantage or disadvantage between using car dolly or trailer?
Thanks everyone for yours amazing help... know i feel better.
