Should I change my Manual shift oil?
I have a 1998 f-150 with a 4.6 and stick shift. I have 135000 on it now and thanks to the forum fixed the 4x4....however I am doing some work on it now (brakes etc) and just wanted to know if I should change the manual shift oil.
It has never been changed is this something that I should change or is it not that important to do on a manual...
If I need to change it how do I do it? I am betting there is a fill plug above the drain and you have to use a hose to get it in there? Just a guess...
Also what oil works best for this.
Thanks Again for the help...this is a great forum!!
Its long overdue for a change and seeing how these M5OD transmission that Mazda supplies to Ford aren't the best, I'd change it now and every 30K from now on. First, check your manual and see what kind of fluid is recommended by Ford. I believe it calls for Mercon ATF in these units. If that's the case any Mercon fluid will work fine, synthetic may give better shift response in cold temps. Second, pop the fill plug. Don't want to drain the old fluid and not be able to get new stuff in there. May take some lube and a breaker bar. Third, drain the old stuff out. Finally, fill till the fill hole with new stuff. If it takes ATF and not gear lube you may need a handpump (found at any parts store or Wally World) or a transmission funnel to get new fluid in. Let us know how the old lube looked and if you have any more questions.
Just Got it changed today...It is about 70 degrees here in Missouri! I purchased 4 qts of Mercon by carquest and asked about a pump to get it in there...They did not have anything so I thought here we go....But I tried the Parts plus in town and they sold me a Suction Gun for $10....I just checked the post and someone mentioned it so I guess it was the right tool!...It did work well...
The Oil was very dark and there were metal shavings on the drain plug like one picture showed...I think I will changed it every so often...Maybe every 50k or so....I am glad I changed it since it did look crappy....Thanks for the pointers!
I just changed my slave cylinder yesterday and while I was at it, I figured, what the hell, I'll change the tranny fluid as well. Since I dumped quite a bit out taking off my driveshaft.
My question is. Can I just fill the transmission through the shifter hole in my floor board?
I have that whole thing apart and figured it would be easier to fill from up top then that side hole.
