check engine light
check engine light
Ok, now I don't know what is going on. Could this be a engine problem instead of a tranny problem? It seemed before that the transmission was shuddering and slipping in the higher gears, and only when I am driving these country roads, pulling up the next hill. Let off the gas going downhill, and then when I oick up the throttle going up the other side, it starts that jerking and slipping. Took it in to Ford and got a tranny service, they told me it had burnt fluid and debris in the pan. Got it back and it still does the jerking, although the shuddering seems to have stopped. I have to drive it with the overdrive shut off so it won't jerk. Even with that, it still does it sometimes when I do the downhill/uphill thing.
Now I am noticing that when I really punch it downgoing uphill, the "service engine soon" light flashes and goes off. I took it to a tune up place, and the guy said it has an old code that reads "all cylinder misfire" or something to that effect. I am wondering if my "slipping" problem isn't a engine tune up problem instead.
Have any of you ever experienced this? Trying to avoid the transmission repair if possible.
Thanks,
TC
Thanks,
TC
on
If they took your money to do something to the trans, it's their problem now. If the trans was too far gone for a fluid change to have helped, they shouldn't have offered to do it. Now that they have, & you're having problems less than a week later - they have to fix it. A refund won't cut it. You paid to get your trans working right, and it's not.
They said the fluid was burnt, and debris in the pan.
4. After normal operating temperature is reached, maintain a constant vehicle speed of about 80 km/h (50 mph) and tap brake pedal with the left foot.
5. Engine rpm should increase when brake pedal is tapped, and decrease about five seconds after pedal is released. If this does not occur, see torque converter operation concerns.
I don't want to spend the money on a tranny then find out it's something else.
The blinking SES light indicates a misfire or other severe drivability problem. I would pursue that first before spending U$$$$ on a tranny.
You need to get the codes read that are stored in the computer. You may want to do the full power hillclimb before the code read to make sure they haven't been erased by too many drive cycles.
List the codes here and we will take a shot at diagnosis.
Firtz
Firtz
