trans fluid change/flush questions...
I've been reading a bit about how to change the trans fluid on my 2001 F150 SuperCrew 4x4, and how it's not a good idea to have a flush done if it's never been done before on a high mileage vehicle.
Looking back in my files, I see that I had a flush done (1st time) at 60k by the dealer - it was called a 'T-Tek Flush' on the writeup. I now have 90-95k on the truck (don't remember at the moment).
would there be a problem with having a flush done, or should I just to a fluid change? or is the fluid fine and I should just leave it alone?
thanks in advance
thanks in advance
Sounds like the filter has never been changed. I would drop the pan this time and change the filter. The inside of the pan could also use a good cleaning. This job is pretty easy. If you suck the fluid out from the dipstick tube it will make this job a lot less messy. It takes awhile, but I just use the top of a liquid hand soap bottle with a hose attached and feed it down the dipstick tube to pump it out I also use this method to replace a couple quarts every once in awhile. Not sure about yours, but my 03 has a reusable pan gasket.
I am curious, when you do a flush, do contaminates not get pushed into the tranny? Or is the fluid being forced out without going through the clutch packs? I did the dealer service at 30,000 which is dropping the pan and changing the filter and about 6 qts. This was what the dealer recommended, they advised against the flush.
Originally Posted by fishx65
Almost forgot, I had a flush done at the dealership on a Taurus about three years ago. The Trans went bye-bye about 900 miles after the flush. I will never be lazy again!!!!!! This might not happen to everyone but it did to me.
The worst vehicles to flush are the late 90's early 00's explorers. The pump pressure is so weak at idle, you have to lift them off the ground, put them in drive and acutally drive it in the air to get the fluid to circulate
