tranny fluid change
tranny fluid change
I've been reading the posts on here regarding changing the transmission fluid on my 2000 F150 automatic with overdrive. There are dozens of conflicting methods and fuid types. Can someone clear this up so I don't ruin my transmission? I just want to do a simple fluid change and possibly a filter change. Thanks in advance.
Should probably flush it. Your local dealer should do it for around $160. They dont change the filter though unless specified. They will run a carbon breakdown fluid through your trans to eat up all the gunk in the lines and valvebody. then they will powerflush the old junk out and flush new in along with a fluid stabilizer. If you just do your basic trans pan drop and converter drain, there is still anywhere from 2-4 qaurts still in your transmission. With that being said, thats still a heavy amount and will contaminate your new fluid.
Do it at the dealer and get that flush mentioned above or it's a waste, let them advise you on a filter change. It's 100% worth it.
They'll use Mercon V most likely, Let them do it , you can't do it yourself as good as they can now, with there updated equipment.
I absolutely hate going to the dealership for anything, but I will for that from now on.
My local dealer offers three types of services:
Simple service. Pan drop, replace filter, refill. $90.
Flush fluid. $160.
Full service. Change filter and flush. $200.
Assuming the transmission has not be serviced before I would recommend changing all the fluid and the filter. An '00 will have a torque converter drain plug so you can drain nearly all of the fluid if you choose to do it yourself. Those of us with newer trucks can only get what's in the pan, 4-5 quarts, without opening up a line. Any fluid labeled Mercon V will work fine. Ford dealer will use Motorcraft Mercon V and a Motorcraft filter both good stuff. If you drop the pan yourself only buy the filter, the gasket is reuseable and you do not need to buy a new one. Clean the pan with some brake cleaner and don't overtighten the pan bolts when reinstalling.
Flush fluid. $160.
All I ever did was use Mercon V and did so even in the transfer case, although there you're supposed to use the dextron, oops, my bad! Every place I hear says switching to Mercon V is highly recommended anyways, just don't mix. In changing, I switched to a TCI pan with 2 extra quart capacity and drain plug (helpful). Let that drain fully, drop the pan, reuse the gasket, but replace the filter, bolt up. Then drain the torque converter, there is alot of fluid in there. Be careful with the plug not to tighten too much, just snug it. There is alot of posts here, so search for additional info. The fluid should be Mercon V though.
Not a fan of the flush but a fluid exchange is OK. Difference is that a fluid exchange uses the transmissions pump to slowly replace all the fluid, took almost an hour on an old Ranger of mine. Flush machines can stir up junk that does not need to be disturbed.
Amsoil ATF is recommended for use in transmissions that require Mercon V. Other sythetics that will work include Mobil 1 ATF and Redline D4. Amsoil will mix fine your older fluid if you choose to drain and fill only.
