Change to "shift on the fly"
Why, oh why would you not want a simpler, and less prone-to-problems setup? Does the floor lever look that bad? Especially if 4WD is used rarely, the manual setup would more likely to keep working (although all 4x4 systems should be exercised occasionally). I understand people's aversion to manual hubs, as it can be a pain to remember to lock them in, but give me a lever over a solenoid-driven system any day.
Andy (who misses his old Ranger's manual trans, xfer case, and hubs)
Originally Posted by figgy
That complicated huh?
Why is it more popular to go the other direction? I like the clean look without that stuff on the floor. I only use the 4x4 occasionally.
Figgy
Figgy
Adrianspeeder
Originally Posted by adrianspeeder
Following the KISS (keep it simple stupid) method is the biggest reason. Less electronic fluff to fail, and that usually happens right when ya need 4x4. My personal preference is manual hubs with a manual transfer case. Not much to go wrong there. Course I also prefer a manual tranny, so I'm a bit biased.
Adrianspeeder
Adrianspeeder
Bottom line is we're moving farther and farther away from the days of yesteryear when low lock meant low-lock!
-Joe
Originally Posted by GIJoeCam
Unfortunately you can't get any of that on a 97-up F-150. The manual case is only manual in the sense that you manually position the shift fork in the transfer case. However, the t-case still relies on the GEM to synch the shaft speeds if you shift on the fly and the GEM controls the solenoids to lock the center-axle disconnect on the front axle. The '04-up trucks are almost as bad, but at least their default, should you lose vacuum, is to lock the hubs, so in a pinch, you could just disconnect the vacuum line from the solenoid to force the hubs to lock. Not sure if you can still get a manual case on the 04-ups though.
-Joe
-Joe
i know you can only get electric case on the fx4 & lariats/king ranches, & i think its an option on the xlt (if they come standard with manual)
do xlts have the center console/shifter?
I always ordered the manual lever as opposed to the ESOF in all of my past trucks, but (reluctantly) ordered the ESOF on my '05. I prefer the manual lever due to the simpler, more reliable system. So why did I go to ESOF on the new truck? Since the center section of the bench seat is no longer movable and Ford insists that you get the small console (with cup holders) on the floor with the manual lever, you essentially end up being able to only seat two people in the front of the truck. In a regular cab truck, that's like stealing 33% of the seating capacity. With the ESOF, I can put a real, live human being in the center for short periods of time.
