Increasing tow capacity
You can never "increase" the tow capacity. Ford sets that and won't/can't change it.
You can do things to make it tow what it should better (as I have) but if you're trying to tow something more, I wouldn't.
You "might" be able to see what an exact truck with a higher rating has that you're doesn't like a taller gear etc. Then change that to get there knowing it's not "changing the rating" per se, but you know what it can do.
jayntguru:
The 7700 option is the trucks GVW rating. It just means that you can put more stuff in the bed. It initially weighs more too, due to a heavier frame, beefed up springs and such. It's the same engine/tranny that a normal F150 with a 6,250# GVW rating has.
Looking at my owners manual, an F250 LD (same as 7700), 4x2 reg cab (or super cab) 5.4 w/3.73 rear has a 13,500 # GCW (Gross Combined Weight) rating. That's the total weight of truck and trailer and loaded up with gas, water, beer, etc. It also says the MAX trailer weight is 8,600# (but, remember, you still have to be below the total GCW).
An F150 4x2 reg cab (or super cab) 5.4 w/3.55 rear has a 12,700 # GCWR and the MAX trailer weight is 8,000#. Again, that does not mean you can expect to tow an 8k# trailer and have your bed loaded to the max either.
BLWN_HD#34
Look into getting some of these.
Overload springs
But, for your ride, I'd think about getting some type of Air Bag setup. Not the kind that allows you to lower or raise your ride, but the kind that just add the "overload" portion.
The springs will make the ride a bit "firmer", where the bags will allow you to go to completely stock again, by just deflating them. Just pump 'em up when you tow.
Overload springs
There are a couple of things to "fix" the sag:
in order of increasing cost
1) helper springs (Hellwig, among others). THese are "extra" leaf springs that you install on your leaf pack and they only come into play when you are towing a heavy load.
2) air bags. You can inflate these to level out the rear of your truck....pretty expensive compared to helper springs.
3) weight distributing hitch. This places the load across the whole frame of the truck, from front to back, and is always recommended for heavy loads or high tongue weights...
not sure on cost of these though...
btolenti:
The helper springs are progressive to a point. Meaning that you still have to put some tension on them when empty or they will rattle. In my case, I had to tighten them up some more after I originally installed them because they started to rattle on bumps when empty. It actually "lifted" the rear end some too. Maybe an inch. For a 4x4, that's a good thing!
Anyway, it's a solution that worked for my needs. As a side bonus, they also eliminated my rear spring "clunk" when stopping and then going again. No more wheel hop on wet roads if I happen to "break 'em loose". The truck just seems to handle better. And the biggest part was that I can actually haul 1000 #'s in the bed and not look like I'm hauling 1000 #'s!
Joe Northern CA:
Specifically, they are the Hellwig LP-25 Progressive Overload Springs.
I got them at a local 4x4 shop, Central 4Wheel Drive. For whatever reason, they sell the mounting hardware separate , but the total cost, including the hardware, was $150 + tax.
I've seen them in other mail order catalogs, and they list the hardware as being separate too, but the prices have always been higher then what I paid.
You could also try RV stores. They usually stock stuff like this too.
Good Luck. I really like mine, BTW.
