New shocks?
New shocks?
I have a 2000 F150 Supercab with the 5.4L V8. Its a short bed. A lot of the freeways here in SoCal have expansion joints and when I drive about 70mph there is a lot of bouncing at the rear of the truck. Can anyone recommend better shocks than stock to help reduce the bouncing?
Right about the Ranchos
The previous posters are correct about the Rancho shocks. I've also owned the 9000's and they are great because you can set them from 1 to 5 for the ride that you are looking for. You can set the front on say 3 and the rear on 4 if the bed is empty. If you have a load, just turn a **** and put the rear on 2 and the truck will handle MUCH better.
Another good choice would be the Bilsteins. They are real good about not re-bounding. They are not adjustable though.
My own recommendation, based on past experience, would be the Rancho 9000 series.
Creole
Creole
Whatever you do don't go cheap and get some of those Explorer ProComp 3000's or whatever the model is for their nitrogen charged "larger" shock. I replaced my leaking OE shocks with those and the back was so stiff and bouncy I was getting whiplashed on expansion joints.
Unless you do some serious offroading or have really large tires I've always found a fresh (albeit expensive) set of OE nitrogen shocks are the best... designed for the vehicle I guess. Well... everyone has their opinion, the Rancho's do sound good with an adjustment feature. Stay away from those you can't adjust cause once you buy'em you're stuck with'em.
Aside from your OE shocks being worn out (@ 52k miles mine are ok), the design of your truck affects bounce on expansion joints more than the shocks - the length of the frame and natural resonance frequency. Sometimes your frame flexes with the right motion and frequency to make expansion joints seem worse than they are. Shocks can help as well as perhaps lower/higher tire air pressure... not much else does any good.
Good luck, let us know how it goes.
Doug,
After much pondering and poor choices I previously made with the Gabriel Monotube and the Bilsteins, I narrowed my choice down to Rancho 9000's and Edelbrocks. I went to 4 Wheel Parts a week ago to purchase the Rancho's and talk with the salesman there about which one was better for sway control...and he quickly said the Edelbrock IAS shocks were my best choice.
I ordered them, picked them up and just put them on today and took a test drive. Results....Awesome freeway drive. I took a "posted" 40 mph freeway transition down here in Costa Mexico at 75 and my SuperCrew handled it just fine. I know the expansion joint bumps you're talking about on CA freeways. I drove up the 55 and headed east on the 73 and I could barely feel the joints on either freeways. I don't think you'll be disappointed with the Edelbrocks.
The salesman did say that he would recommend the Rancho's if my truck was a 4X4. He also said the Edelbrocks are much smoother on paved roads and freeways than the Ranchos. Therefore, my decision was made.
Good luck,
Kevin
Good luck,
Kevin
