leveling kit or toresion bar adjustment
Thanks man!
Cranky the bars is very easy. Just make sure that the truck is on level ground. Measure the distance from the center of your wheel to the fender lip. Find the adjustment bolt which is in the cross member were the bars end, and turn it about 1 turn. Bounce the front of the truck to get it to settle a little bit and then measure again on the side you adjusted. Do the same on the other side until your even. Repeat the whole procedure until you're up to the height you want and even on both sides. I think with mine, I went up 5 turns on each side. Oh by the way, it's an 18MM socket for the adjustment bolts. The picture in my sig was taken before I cranked them so don't go by that. Good luck and have fun.
Bob
Bob
I haven't yet. Some people say they need it right away but my truck doesn't pull so I'm going to wait until it gets a little warmer and take it in for an alignment. It's due for one soon anyway. By the way, the whole job of cranking up the torsion bars should take you less than an hour to do. It's pretty simple.
Bob
Bob
Thanks again, you were right, it only took about 30 mins and it was an 18mm socket. I cranked about 6 turns on each bolt and it leveled it out just perfect. Although i still had to put a 1" spacer between the bumper and frame where it bolts on to give me enough clearance for my BF Goodrich A/T's. But without cranking, the wheels and tires wouldn't have worked. I would post a pic for you if I knew how, anyway, thanks again for your help.
