The Do's and Don'ts of Lifts
Old 09-06-2011, 10:48 AM
pizzaman711's Avatar
np. if you got a question on it i can help
I figured you would with the new truck ha. How you liking the super duty?
  #32
Old 09-06-2011, 02:38 PM
thejake1989's Avatar
i like it alot. Its got tons of power and im just starting to get into it.
  #33
Old 09-06-2011, 04:16 PM
jerhelo's Avatar
Originally Posted by RichardM
jerhelo, does your friend happen to have a spindle lift? im getting one and they push the tires out 1.5 inches and im just curious if the 1.5 inch spacers perfectly match that? also how do the bolt pattern measurements work/ 5 x 4.5 and 5 x 5. i realize the first number is the number of wheel lugs currently on the factory rotor. is the second number the distance between 2 of the lugs across from eachother?
No, he has a 4x4. He did it because the wheels needed less backspacing. He likes them, they add about an extra 1" or so of width. He had wheels with 5.5" and needed 4.5" so he bought them....
  #34
Old 09-06-2011, 06:36 PM
archangel2003's Avatar
great write up
  #35
Old 10-16-2011, 12:40 PM
Alex_4.2L's Avatar
hey pizzaman maybe you could add that with the coil spacer you will have to get an adjustment after its installed.
  #36
Old 10-16-2011, 05:01 PM
You referring to an alignment?
  #37
Old 10-16-2011, 10:50 PM
Alex_4.2L's Avatar
yes an alignment
  #38
Old 10-16-2011, 11:23 PM
I'll go back and add it when I'm not on my phone ha it's too much of a pain to do it on here.
  #39
Old 11-05-2011, 02:59 PM
Big JoJo's Avatar
good info, thanks
  #40
Old 11-05-2011, 03:59 PM
Big JoJo's Avatar
good info, thanks
  #41
Old 01-19-2012, 01:12 AM
Unseen's Avatar
just saw this thread. Great write up man!! thank ya for posting
  #42
Old 01-19-2012, 09:31 AM
Thanks man!
  #43
Old 01-24-2012, 05:41 PM
Cowboywrench's Avatar
Pizzaman711
I have read this entire thread, and I still have a question. Perhaps with a little more research I might find the answer in another location, but I'll throw it at you because you seem to know of what you speak. I recently bought an old '90 model with the 4.9 M5OD 4X set up in a long bed. She has seen farm use, and who knows what other abuses over the years, and currently is sitting on 32's. My issues are that the rear seams a little spongy, but mostly that the front coils are held up with two threaded rods on some brackets.
I know jack diddly about suspension, and I'm not looking for some radical lift. Particularly I'd like to simply update the front, and maybe the rear, suspension with a little more lift than it has, and be able to run 33's if I chose to, and keep leveled the truck out.
I don't need a silver platter, but some sound advice for somebody who isn't a suspension guy would be appreciated. Any help you, or the others around this blog, would offer me towards brands, costs, what to do and not do, will be taken in and, again, appreciated. Thank you.
  #44
Old 01-24-2012, 09:36 PM
VoltageTech's Avatar
so a 2.75 inch level kit is to much for 04-08 4x4?
  #45
Old 01-24-2012, 09:38 PM
06yz250f's Avatar
If your springs are spongy front and rear definitely look for a kit with new rear leaf springs and new front coils.
There is a section for your body style truck where you will get more help, i'm not that familiar with your year truck. As long as you stick to a name brand you should be in good hands.
Quick Reply: The Do's and Don'ts of Lifts
