2WD Leveling Kit
Old 04-26-2009, 06:46 PM
kingranch4's Avatar
2WD Leveling Kit
Where do I get one and how do I install it? I have a 2008 KR F150 and the rear sits up about 2 inches too high...help me out here folks!!!
Old 04-26-2009, 07:18 PM
jay888811's Avatar
get a 2" or 3" rear shackle , i just put it on my truck, took 45min a side, comes with instructions, cost less than 75 bucks, but first check and make sure you dont have a 2" block on your truck cause you could just pull the block out in stead, some came from factory with a removable block.
Old 04-27-2009, 01:35 AM
Munkey's Avatar
Are you looking to lower the rear or lift the front?
Old 04-29-2009, 08:22 PM
black5.4beast's Avatar
from the original thread post it sounds like he wants to lift the front. i just found a very good looking and cheap level kit on hellbentsteel.com
i think i might be putting it on my truck someday.
i would stay away from the 3" though ive heard 3 inch kits cause problems while offroading
Old 04-30-2009, 12:43 AM
Marshall-Law's Avatar
I like the idea of lifting the front to match the rear much better. There is a reason the rear sits higher, load capacity. If you want to use your truck for what a truck is made for lift the front don't drop the back.
Give Summit a call I'm sure they have one.
Old 04-30-2009, 03:27 PM
BlkButy's Avatar
AutoSprings 2" - get on ebay!
I love mine - Also an 08 SCrew but XLT.
Old 04-30-2009, 10:09 PM
wandell's Avatar
I agree.
Old 09-13-2009, 12:16 AM
Cougars1999's Avatar
Measurements after leveling
What are your measurements after leveling? I'm about to install Bilsteins on the 2 inch setting and I'm debating on whether or not to install a 1.5 inch rear block. Thanks!
Quick Reply: 2WD Leveling Kit
